Bluetooth RX/TX
eastcoastkiter
Bluetooth RX/TX
Hi there,
I'm tring to connect my Vesc 6 to a bluetooth module in order to connect it to the Computer or Mobile.
I have tried to connect via HC-05/06 module which I'm using in my arduino project and AT-09 komp. HM-10 Bluetooth 4.0 Board BLE  board.
I also tried to put and arduino "in the middle" and copied all data from and to the serial busses.
Is there any documentation out there? Do I need to send something in order to receive data like a startup sequence?
I alos tried to connect via Vesc app which neighter works. The bluetooth module on the arduino (without vesc) works as a charme.
I would be greatful for any hints.
Thanks,
Rene
Plug  BLE Module into VESC (NRF Module with VESC firmware), make sure UART is active (eg select PPM end UART). Open VESC-Tool App and hit SCAN.
HM 10 will not work.
bears0
I am working on a fix for this. it has to do with the UUID that is programmed into the app. I will let you know when i finish the compiled version. I only have android so thats what im testing it on
Andrew Cline
BessieGilreath
The outside direction of the project is filed for the accounting of the pure sciences for the kids. It is shared among the uses of the Fortune Jack for all right and ital. parts for the field. The accurate opening is done for the frustration for the counters in the improvement of the blocks for the comments.
jzy1115
Last seen: 3 weeks 17 hours ago
I have a VEC tool that can use hc-05
radler
regular DX-BT18 works between VESC and windows VESC-Tool for me, even realtime data is ok. It fails with android app or MacOSx VESC-Tool.
dancing with bikes
