"bad detection result received" impossible to achieved motor detection !
titimomotete
Hi all there !
I can not acheived the configuration of the motor of my e-skate. I connected Vesc tool 1.06 to my Vesc 4.10 and try to configure it according to my hardware :
I read most tutorial and search forums but i did not found a solution. I let "app settings" and did not change anything yet.
Here all my settings :
The motor could handled 80A but i prefer to be careful.
Battery is a 10S. I try at 20V cutoff but with no more result.
Value found on electric skateboard builders :
That the power of the motor :
And here i get the "bad detection result received" when i launch detection. The motor rotate with coughing three or four times then detection process stops
Here and at next screen i changed nothing.
I try at full default values but nothing change.
Did i made an error somewhere ?
Thanks if someone has an idea why the detection failed systematicaly !
titimomotete
I took a video of the result of failed motor detection :
https://youtu.be/GR5LDx2jb1k
I tried with I at 20A and 50A and ERPM at 300 but it worse !
doom
Same here, worked fine before, latest VESC-tool wanted to upgrade firmware, did that and now it won't detect BLCD anymore.
FOC works fine but it won't help me, the motor is too beefy for FOC mode :-(
