Problem to start bldc in vesc tool vesc-mini4 esc
uav-orion
Last seen: 7 years 3 days ago
Hi all!
Maybe its easy, but i dont know how))
I cant start any motor with esc vesc mini4.
I tryed wizard, its dont recognize motor. Try to another esc the same truble.
Video https://photos.app.goo.gl/vaA5WQC52XfppZet6
Please help)🤓
Wisdomwagon
I have sort of a same problem. My motor got recognized by wizard but it ends there. I cant spin the motor after wizard did its tests and gave me the results. It tried to start it with arrow keys and I can hear burring whining sound but nothing happens. If I try to spin it with my hand, it bursts but cogs immediately.
Try choosing another motor type in your wizard start, at least for me it did something different. I have no idea what that has got to do with anything at all but it does.
_______________________________________
Cool but not frozen.
uav-orion
thank you for replay, but its not helps((
is someone have any other variants?
Heli.by
electricfox
electricfox's picture
Last seen: 1 hour 41 min ago
With my motor I had the same problems. In my 7KW Innerrunner motor thread I wrote this: "In the beginning the motor was cogging while driving after detection. Then after changing Motor flux linkage from 15.30mWb to 13mWb and switching frequency from 20khz to 60kHz it works fine now."
Thats an example. So play with those values first.
Oliver
Hard to say. Something called VESC mini4  doesn't exist. This is third party hardware, VESC based. Does it relibly spin other motors? Did you try another ESC or original VESC with same settings?
Higher switching frequency should not be needed for this motor, picking bigger motors on wizard determines how much amps are used during detection. Don't go to big when trying out things!
uav-orion
thank you all. when i solve the quest i will post here!
Heli.by
