Vesc-Tool mobile on Play Store.
12 posts / 0 new
*The 2019 VESC-Tool App is about to arrive!**
For 2019 Benjamin has packed a nice present for the community.
On Saturday we will see a release of the Mobile VESC-Tool in the play store.
The new VESC-Tool is super convenient to use and is prepared to work seamless with upcoming hardware releases. Everything is fully automated and in consequence the complete setup is now nailed with 3 to 5 clicks only. Setting up a dual or quad drive takes just as long as setting up a single VESC.
There is also a new VESC availabe. The all new VESC SIX Plus just arrived.
Visit www.trampaboards.com
These are some of the new features you will benefit from:
* Auto motor detection including sensor detection for all VESCs simultaneously.
* Motor detection in FOC open loop
* automatic and accurate current settings for motor and battery (can still be manipulated manually).
* FW updates to all VESCs in one hit
* Configuration of all VESCs in one hit
* Profiles (top speed, current limits, power limits, brake etc.)
* Profiles changeable while actually riding the board (you can’t feel the switching)
* permanent and non permanent profiles
* profiles are written to all VESCs simultaneously and instantly
* Smooth low speed braking capabilities (braking close to stand still)
* Analogue cockpit (speed, power, rpm, duty cycle, current, battery)
* Statistics and estimated range (really accurate now)
* Data from all VESCs is now used to calculate the values
* Board can be given a name
* Communication between remote, phone/tablet and VESCs simultaneously (triangular communication).
* pairing of remote and phone/tablet to VESCs (stops others to interact with your VESC/board).
* new remote features to allow display of values on remote
* The new VESC-Tool is fully prepared to work with the upcoming hardware releases
* The new VESC-Tool will be fully compatible with older hardware like 4.xx
* Support for UAV-CAN (e.g. for multicopters and robots)
* and many more…
Have a look yourself: https://youtu.be/LPjsen0D2mE
Here is the link to the App:
https://play.google.com/store/apps/details?id=vedder.vesctool
Last seen: 3 months 23 hours ago
Really awesome stuff! The new motor setup looks perfect.
ebikerevolution
Woo!! Stoked to use it!
Very cool. I'm particularly excited about switching profiles on the fly.
Do you have a link to the app? I can't find it.
Click on VESC-Tool in the menu. Click on App picture.
jaghori.sasan
Ecyclist
Ecyclist's picture
Is it possible to use GPS signal for speed reading on this new VESC app?
Les
Not yet. We use the wheel diameter and gearing info. GPS speed is easy to obtain from various tracking apps.
Ecyclist
Ecyclist's picture
Yes, but it would be nice to have speed reading on one screen on my mid drive e-bike. No problem my cateye strada will do for now.
Thanks for your quick reply.
Les
Jes Grant
Hi All,
Could do with some help please.
I uploaded the new VESC tool, connected to VESC 6 (Trampa mountain board) and the software advised firmware needed updating.
Tried this several time but the VESC 6 seemed to still retain firmware version 3.4, eventually after several attempts when trying to connect got a message indicating the firmware could not be read.
However the old VESC tool still connected and I could still adjust settings, that was until last weekend where the old VESC tool is now showing the same message.
An esk8 forum suggested each VESC 6 need the firmware updating individually , which I have tried and initially the slave VESC 6 asked to update the firmware, but after first attempt I got the firmware could not be read message again.
I appear to be able to connect to the master VESC  6 via USB cable and laptop, which shows the the firmware to be 3.4 still. Tried re installing 3.4 firmware from the laptop, but both mobile versions still exhibit the same not able to read firmware message.
 Ahy help or suggestions greatly appreciated.
Many thanks
Jes
Boesila
Hi guys,
short question: Should the app work with the bulid in NRF modul from the VESC6 (beta)?
I updated the firmware of the VESC6 over my PC, donwloaded the app for android.... when I do the scan in the app it does not find the VESC6 (BT is on at my phone) .
Best wishes
boesila
