Always get Fault:DRV in FOC mode during startup .
stone_1706
stone_1706's picture
Hello ,
  I diy a VESC6 board and double checked schematic and PCB, it looks good.
 In FOC mode ,I got Fault:DRV during startup every time, during in BLDC mode  it work fine and detect motor R,L is OK.
What's going on in FOC mode ? ....software problem ? hardware problem ?
Stone
stone_1706
I do not want to modify DRV8301 chip setting ,because the default setting of DRV chip is OK, ,so in my design I remove SPI signals for DRV8301.
Is it OK ?
sam.vanratt
Hi Stone
did you try to man. set a different diagnostic setup (I, eRPM, ....)?
Cheers
Sam
stone_1706
HI Sam
I will try it .
Thanks for your reply.
Stone.
