Vesc is not working
Patryk
Vesc is not working
I've connected vesc to my laptop and I tried to update hardware to 410&411&412 version. I thought that everythink was all right, becouse laptop was connected (serial) to COM5 and it was written Fw:3.40, Hw 410. So I tried to set up motor setting wizard. I clicked bldc type after that I set up motor current limits, battery current limits. I choose voltage limits. After, I choose no hall sensor. And I tried to detect bldc parameters. I saw that motor is not spinning and then in my computer was written that detection failed. After that vesc is not working. What should I do?
What kind of Hardware do you use, manufacturer? Is there still LED light when you plug it in?
Patryk
So what I did is that I have bought brand new Flipsky vesc 4.12 from ebay. I have updated firmware to 3.40 and hardware to 4.10. Next I have set up remote parameters and battery voltage and current limits. All in all when I tried to detect bldc parameters I received bad detection and when I tried to set up FOC I received R=0.
MARTYNIAK1
Patryk
When I connect vesc to The battery using anti spark plug I can see Green and blue light. And also when I try to click to speed up or break on my remote, or whan I try to set up something in vesc tool like "bldc detection " or foc detection, I receive red blinking, flashing light between Green and blue.
MARTYNIAK1
Patryk
On the heatshrink it is written hardware 4.12 and firmware 3.34 but unfortunetly when I connected vesc to Computer it is written that supported firmwares are 3.39, 3.40 . So I update 4.10&4.11&4.12. I have written to flipsky company and they told me that it is the latest firmware and hardware
MARTYNIAK1
