Fault:DRV8302 DUAL V4
Lzx19961014
I used a dual V4. last week, and I found that there was a problem on the uphill. There may be problems when the current is greater than 30A. "Fault code DRV 8302". Is this happening to you?
FW:3.40
Link to HW, exact setting used, motor used, battery used.....
People need some info to help.
Lzx19961014
Yes, I have tried several times, but there are problems in FOC mode. There is no problem in BLDC.
stone_1706
stone_1706's picture
I got same problem in FOC mode. There is no problem in BLDC.
Do you fix this issue ?
Stone.
