Adding capacitors with long power cables?
rich
It would be interesting if there is a difference to V4 regarding adding capacitors with long power cables. I just received 2x VESC 6 (niiiiice!) and thinking about mounting them on the back of my trampa. Right now I have the V4.12's inside the battery enclosure and long phase wires. In my case the power cables would have a length of about 50-60 cm.
Last seen: 2 days 6 hours ago
I was talking about that and doing some simulations in this video:
based on my conclusion it is not really needed, and you would have to put the capacitors very close to make any difference at all.
rich
Wow, what a video, respect! I couldn't follow all steps due to lack of knowledge but my question is answered, thanks!
rahmaev_a_o
Last seen: 8 years 3 weeks ago
How to choose ESR?
How to choose the capacity?
I want to reduce the capacitor.
Basically lower ESR = less heat = caps last longer before the vesc goes boom
For capacity you need to simulate the circuit with his PSpice file. Takes a while before you understand all the variables. Main one being inductance, if its too high it doesn't matter how much capacitance you have it will always blow up.
rahmaev_a_o
Thank you
50cm should be fine without additional caps. Make sure that the wires are thick enough (AWG11 or 10).
