Question to get a new Motor Running
speedy
hello , i have a motor witch i like to run with vesc .
the motor runs in BLDC or FOC mode but does not reach its maximum speed.
the motor should have 200rpm (20inch wheel) but only reaches only 80rpm @ 24V
how can i set the rotating field frequency of the motor in the vesc software?
here is a datasheet abaout the motor
https://ibb.co/e1ZNEJ
kind regards
christian
You need to post your settings to get a good reply. Either screenshot of setup or export the XML files.
FILE >> Save motor configuration xml as...
FILE >> Save app configuration xml as...
How many Amps did you allow. Battery Max, Motor Max?
Also note that the motor is 36/48V rated.
Motors are not really voltage rated as long as you stay within certain limits (e.e not apply 100+V).
Per Volt you get X rpm (KV value). You can't really make the motor spin faster if the voltage is to low.
To reach your desired RPM you need higher voltage. The company offers 36V or 46.8V battery packs!
Frank
