Failure of FOC mode brake
9 posts / 0 new
jzy1115
Last seen: 6 days 4 hours ago
Failure of FOC mode brake,Fault is Drv
Yeah, we're gonna need a bit more information.
jzy1115
This problem will only appear in the FOC mode brakes, FOC acceleration is no problem, BLDC is no problem,
Brake DRV error at low speed, and then brake failure, the following error information
Fault: FAULT_CODE_DRV
Current: -2.0
Current filtered: -7.4
Voltage: 40.87
Duty: 0.014
RPM: 2238.6
Tacho: 4164
Cycles running: 11314
TIM duty: 120
TIM Val samp: 2
TIM current samp: 4200
TIM top: 8400
Comm step: 0
Temperature: 24.33
Current: -11.5
Current filtered: 7.6
Voltage: 40.84
Duty: -0.022
RPM: 1836.6
Tacho: 4298
Cycles running: 289
TIM duty: -186
TIM Val samp: 2
TIM top: 8400
Comm step: 0
Temperature: 24.23
Sealight333
I have the same problem with the (Maytech) VESC 4.12 fw 4.18 with 6S battery with 2 different type 190KV BLDC motor. It happening at the very first Break so no FET overheat!
Sealight333
Have anybody a solution for this DRV error?
iscle
same problem here! with maytech vesc too! Maybe they had a bad batch?
jzy1115
Yes, I bought another brand of VESC. There is no such problem. Their batches are not good.
jzy1115
My VESC is Maytech
iscle
This issue is solved by adding a paralel capacitor to C18. In total I have arround 13uF capacitance and it works great.
