how to stop regenerative braking option ?
tauhid.ann
hello everyone i am tauhid from Bangladesh. i have brought a vesc and using it for my Ebike . Now i am having some issues with regenrative braking option as it stopping my bike so quickly that one day my motor mount get stucked in spok . how can i stop this option and let my motor spin freely with wheel after i release my throttle. i am using a 3 pin throttle and using duty cycle mode . min voltage .06  and max voltage 2.60. i dont understand this parameter very good. what can i do to stop this braking option ?
Sounds like you are using the wrong ADC app. You need to use Current or Duty Cycle modes and configure the throttle mappings correctly.
Or you can just set the battery current max regen and motor current max brake to 0A. Which will disable all braking.
Last seen: 1 hour 58 min ago
Duty cycle mode is not really recommended on an ebike. Give current control a try.
tauhid.ann
thanks you very much every one . just need one more help can u guys help me with current mode ? i dont know to configure it .
motor = sk3 6364
battery =  2 turnigy 11.1 v 5000mAh (connected in series to get 22.2 v)
arvidb
To configure current control, select ADC under App Settings in VESC Tool. Then change Control Type to Current.
tauhid.ann
thanks a lot
