VESC not responding to Controller
jcab
Using the VESC tool, I updated my 4.12 Flier VESC from 2.54 Firmware to 3.34 Firmware. The update was successful (according to the VESC tool), but now the VESC will not respond to input from the controller. The VESC was communicating fine with the receiver until after the firmware update.  I have tried a few things to troubleshoot this, but no success.
Transmitter/receiver –
  1. Redid the binding process – still not communicating
  2. Tried all channels – Still not communicating
  3. Tried using another VESC to insure the Transmitter/Receiver was working correctly – Worked fine on 4.1 hardware/2.18 firmware
  4. All lights on Transmitter/receiver indicate that the connection between the two are active/correct (ie: steady light on both)
  5. Tried a different Transmitter/receiver – still no communication (but this trans/rec works fine on second VESC)
  1. VESC –
    1.  Reapplied Firmware update – still not communication with controller
    2. VESC tool communicates with VESC correctly – can change settings, they are saved and applied
    3. Rebooting VESC after each change – still no communication with Receiver
    4. When using the VESC tool, I can control the motor and it functions correctly (ie: The motor accelerates/brakes/etc. using the arrow keys on the keyboard).
The problem seems to be with the VESC recognizing the receiver.
Any ideas on what I can do to solve this?
arvidb
Last seen: 7 years 3 weeks ago
You are using the PPM app, right? Have you tried selecting No app in VESC Tool, applying that change, and then changing back to PPM (and applying again)? Might be worth a try...
jcab
Thanks for the advice,  arvidb, that worked! Changed to No App/Off, wrote the app config, reboot, change the settings back to PPM/Current No Rev, write app, reboot and I am up and running! Thanks again!
arvidb
You're welcome, nice that you got it working! yes
Popeye
Hello, at the moment I have the same problem.
I completed all settings for both Vesc (motor & controller) . After that I want to do it a last time with can bus connection.
But something happens and the controller lost the complete connection.
(Flipsky controller 2,4ghz)
And Its not possible to reconnect.
I hope someone have  a solution for me.
Best regards.
Martin
Martin
