Vesc Pronto - Inputs of internal expansion
speed3r
Last seen: 4 days 11 hours ago
I recently bought a VESC Pronto.
I am struggling since two days with sth. that should be really easy:
Read the inputs of the IO-Expander but I do not find documentation about this.
(Why though ?!)
The slice of the schematic in the datasheet shows:
"Cruise", "Neutral", "Mode", "Reverse" and so on go to the TCA9535 which is connected over I2C to the ESP32.
So my attempt is:
Use I2C to readout the TCA9535 and forward this over CAN to the Pronto.
I can configure the TCA.
I can write and read back its registers.
My problem:
The inputs are always shown as 0, no matter if I pull the pin high or not.
My questions:
1) Is this the intended way to read the inputs of the expansion-chip?
2) If yes, am I missing something? My Testscript follows below. if someone could have a look.
3) I had to swap i2c-pins to read back the registers correctly. Is there maybe a mistake in the schematic or documentation or am I doing sth. wrong?
4) How to contol "pull1" or "pull2" net? Am I correct that these are intended to be controlled?
I am using this script to read the inputs in the terminal:
;start i2c:
;(i2c-start 'rate-100k 20 21) <-- does not work?
(i2c-start 'rate-100k 21 20)    ;(i2c-start optRate optPinSda optPinScl) from
;prepare buffer for i2c-receive:
(def buf (array-create 1))
;write to register 0x6: configure all pins as inputs
(i2c-tx-rx 0x20 (list 0x06 0xFF 0xFF) nil)
;read back registers:
(i2c-tx-rx 0x20 (list 0x06) buf)
(print (str-merge "Config Port0: 0x" (str-from-n (bufget-u8 buf 0) "%02X")))
(i2c-tx-rx 0x20 (list 0x07) buf)
(print (str-merge "Config Port1: 0x" (str-from-n (bufget-u8 buf 0) "%02X")))
;function to read one register:
(defun read-port (reg)
    (i2c-tx-rx 0x20 (list reg) buf)
    (bufget-u8 buf 0)
;loop: read and print to terminal:
(loopwhile t
    (let (
        (p0 (read-port 0x00))    ;write to var p0
        (p1 (read-port 0x01))    ;write to car p1
        (print (str-merge "Port0_d: " (str-from-n p0)))
        (print (str-merge "Port0_b: " (str-from-n p0 "%08b")))
        (print (str-merge "Port1_d: " (str-from-n p1)))
        (print (str-merge "Port1_b: " (str-from-n p1 "%08b")))
        (sleep 0.2)
I appreciate every help!
Thank you and have a nice weekend!
Edit: Add picture of Pull 1 / Pull 2
speed3r
Regarding switching the pull-Network,
turns out the answer is in the schematic.. I was too blind to see it:
Pin 17 controls pull-down or pull-up of the network..
Regarding my posted test-script:
1) There were two brackets missing in the "read port" function.
2) The formatting in the print-instruction did not work correct. (I prefere Bitmasks, but it did not work well)
3) The "pulling" was missing leading to a lift of the hole network with one pin high.
This test-script worked for me, in case somebody is let here by a searchengine:
;start i2c:
(i2c-tx-rx 0x20 '(0x06 0xFF) nil)
;write to register 0x7: configure all pins as inputs except P17. this is an output
(i2c-tx-rx 0x20 '(0x07 0x7F) nil)
;pin 17 as low:
(i2c-tx-rx 0x20 '(0x03 0x00) nil)
    (bufget-u8 buf 0)
(loopwhile t
    (let (
        (sleep 0.2)
Last but not least Benjamin told about this example using the Expansion board: https://github.com/vedderb/vesc_pkg/blob/main/vl_bike_39p/code_esp.lbm
There is also a package for the TCA9535 available: https://github.com/vedderb/vesc_pkg/blob/main/lib_tca9535/tca9535.lisp
which is great.
For me I know where to look next time.
Cheers.
