Cruise Control on VESC 75200
djambobuksne
Hi, I have a Flipsky FSESC 75200 Pro V2.
I have an accelerator throttle on ADC1, a thumb throttle for breaking on ADC2. My app setting is set to ADC, but I also have a Flipsky display connected on UART.
Everything works perfectly, but I'd like a cruise control button.
What about ADC15, what about the SERVO pin? Is the SERVO pin an input or an output? Can I wire in another button?
Should I make an Arduino take the accelerator and break signals and generate a single PWM so I can use the ADC2 pin for cruise control?
CRTZ
I manage to use the adc15 with lispbm script on the flipsky 75100 pro v2. I'm currently working on a vescpkg for e-scooters and i'm currently using the extra adc to control dual drive mode on dual vesc hardware or for single drive the cruise control. If you just need the cruise control just make a simple lisp to see that pin and connect with a button to the 3.3v so 0v=no-cruise 3.3v=cruise control. You can do this with ai in just ten minute.
