In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current. Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
residential excavation
Just had a great experience with their residential excavation team—professional and timely!
wow
Rakebit tether casino genuinely stands out in the crypto gambling space thanks to its focus on stability through USDT. The platform’s ability to eliminate worries over price fluctuations gives players a sense of security that’s often missing in crypto casinos. With fast transactions and transparent gameplay, Rakebit delivers a seamless experience. It’s easy to see why many are calling it the best tether casino for consistent and fair gaming. If you value predictability in your crypto bets, Rakebit really delivers on its promise.
I usually use gpt chat for
I usually use gpt chat for best settings
Cash App Login
Securely log in to your Cash App account to send and receive money, manage your Cash Card, and access your transaction history anytime. Enjoy fast, easy mobile payments with top-tier encryption and fraud protection. Whether you're paying friends or investing in stocks and Bitcoin, Cash App keeps your finances at your fingertips. Log in now." Cash App Login | Cash App Login
Need reliable Java assignment help
Need reliable Java assignment help? AssignmentHelpPro is here to support students with expert assistance in all aspects of Java programming. Whether you’re working on basic Java concepts, object-oriented programming, data structures, or advanced Java projects, our team of skilled programmers delivers original, error-free, and well-documented solutions tailored to your academic needs. We ensure your assignments are clear, efficient, and follow your university’s guidelines. With affordable pricing, 24/7 customer support, and timely delivery, AssignmentHelpPro is your trusted partner for excelling in Java programming assignments.
If you are ready to embark on an unforgettable gambling journey through online casinos in Australia, Frumzi Casino will be the perfect companion. Unique slot machines with a modern design, a live casino with real dealers, profitable bonuses - all this makes every visit to the site exciting. There is no boredom or monotony here: each game opens up new opportunities, and generous offers help to prolong the pleasure of the game. Register and discover all the facets of gambling today.
Best emergency washing machine repair in Jupiter, FL
When your washer breaks unexpectedly, you need the best emergency washing machine repair in Jupiter, FL. Fast response, expert solutions, and dependable technicians make all the difference!
Small kitchen remodels in Elmhurst, IL
Small kitchen remodels in Elmhurst, IL can bring big results. Maximize space, improve flow, and update aesthetics with custom solutions tailored to your needs
Is It Worth Using Assignment Writing Services in the UK?
In today’s fast-paced academic environment, students across the UK are facing greater challenges than ever before. From managing multiple subjects to meeting tight deadlines, the pressure can become overwhelming. This often leads students to search for professional help online. A common query among them is, “Are assignment writing services UK really helpful?” The answer lies in understanding what these services actually offer and how they can contribute to academic success.
One of the most significant advantages of using a reliable assignment service is the access to experienced academic writers. These professionals have expertise in various disciplines and are familiar with UK university guidelines. They help craft well-researched, properly formatted, and plagiarism-free assignments. Visit at MyAssignmentHelp to explore one such platform that has earned a positive reputation among students for delivering high-quality academic writing tailored to specific university standards.
While many students initially hesitate to seek external help, they soon realize the time and quality benefits these services provide. For instance, balancing part-time jobs, classes, and personal commitments often leaves little room for in-depth research or editing. That’s where MyAssignmentHelp comes in, offering students a practical way to meet deadlines without compromising on quality. When done right, academic assistance becomes a valuable learning tool rather than just a quick fix.
It’s also important to note that assignment writing services aren’t just for students who are struggling. Even high-achieving students use these services to enhance their work, get feedback, or improve their writing style. These platforms cater to a wide range of subjects, from business and law to engineering and humanities. Students can choose services based on their needs—be it essay writing, case study help, or dissertation guidance—ensuring flexibility and academic growth.
To conclude, assignment writing services UK are not just a trend but a practical solution for students aiming to manage their academic workload efficiently. Choosing a trustworthy service allows students to meet deadlines, maintain academic performance, and deepen their subject knowledge through well-structured and clearly explained assignments. The key is to use these services wisely, ensuring they contribute to your learning and long-term academic goals.
Relax
My girlfriend and I wanted to try something new for date night. Searched for a site with fun games. Came across Lets Lucky Casino, and it looked cool. This Australian platform’s loaded with pokies, poker, and live dealers. The welcome offer is ace, with free spins, cashback, and weekly bonuses. Easy to use, secure, and quick withdrawals. Support’s always there. Made our night special, we had fun!
Assignment Help
Not gonna lie, I was skeptical at first, but Native Assignment Help Australia really proved themselves. The feedback I received from my professor improved after I started using their Assignment Help service. You can tell these guys know what they’re doing – every instruction was followed to the letter, and the formatting was textbook perfect.
limo hire
We used their limo hire for our corporate event—professional, punctual, and spotless vehicles!
electrician near me
It's refreshing to use a site that helps you easily find electrician near me with real user reviews.
This VESC® configuration
This VESC® configuration tutorial is a great guide for anyone working with BLDC motors and FOC mode. Using Hall sensors adds precision, and having the latest VESC-Tool version is key. While optimizing your setup, visit ApkTuti.com for free Game & App Apk download and secure APK Downloads for Android!
Phantom Wallet Extension
Phantom Wallet Extension and Cash App Login offer secure, user-friendly access to digital finance tools. Phantom enables seamless Solana token and NFT management, while Cash App Login provides easy entry to money transfers, Bitcoin trading, and stock investments. Together, they empower users with fast, secure, and convenient crypto and finance experiences. Phantom Wallet Extension | Cash App Login
I love how each piece feels
I love how each piece feels relevant and genuinely a little to the left useful, whether it’s through tips, stories, or research
Thanks for the clear idea
Thanks for the clear idea!Create your own bold Charli‑inspired album art in seconds—with Brat Text Generator: style, simplicity, and instant shareability.
Thanks for the clear guide,
Thanks for the clear guide, Frank! Setting up the VESC® is much easier with your steps. It actually reminds me of how DeepSeek fine-tunes AI models-both need precise calibration for top performance.
The VESC motor setup process
The VESC motor setup process emphasizes precision, similar to how ChatGPT Nederlands can be tailored to specific tasks. Just as adjusting motor settings ensures optimal performance, using ChatGPT effectively requires understanding its capabilities. Both involve fine-tuning for safety and efficiency, ensuring users can maximize the benefits of these tools.
game
Setting up the motor using the Motor Setup Wizard is a real pleasure for those who like their equipment to run like clockwork. Everything is clear, intuitive, and at the same time gives you a sense of control. It reminded me a little of
https://sixty6.com/ — when you go in for your daily bonus and get not just a reward, but a pleasant ritual. The same excitement, but without the pressure, because this is a social casino where the main thing is emotions, relaxation, and drive, not money or bets.
Eggy Car
This is a great starting point for VESC configuration! I've been tinkering with FOC mode using Hall sensors lately, and it can be tricky to get the settings just right for smooth operation. I found that careful motor detection is key. It's amazing how much fine-tuning can impact performance and efficiency. I wonder if these settings would work well on a small electric vehicle like, say, an Eggy Car project? Thanks for sharing the tutorial!
Good idea! image size reducer
Good idea! image size reducer, thanks for sharing this information!
The Block Blast Solver doesn
The Block Blast Solver doesn’t just solve puzzles—it makes me a better player. now i understand how to prepare the board for bigger clears and longer streaks.
That Motor Setup Wizard
That Motor Setup Wizard tutorial is incredibly detailed and helpful for anyone configuring a VESC with a BLDC motor. With modern tools like ChatGPT Deutsch kostenlos, even complex technical guides like this can be summarized, clarified, or adapted for different skill levels, making it easier for beginners to follow each step with confidence.
The review highlights the
The review highlights the clarity of the Motor Setup Wizard tutorial, but the real value lies in how modern AI, like the latest チャットgpt ログインなし model available free at GPTJP.net, can simplify technical complexity. By tailoring explanations for different skill levels, it enhances accessibility and empowers beginners to engage confidently with advanced tools.
An online integral calculator
An online integral calculator quickly solves definite and indefinite integrals, providing step-by-step solutions. It simplifies complex functions, helps students verify answers, and supports learning by visualizing integral processes interactively.
Dubai Call Girls
This platform offers excellent insight into companionship options for travelers. I really appreciate the variety shown on Dubai Call Girls.
Call Girls in Dubai
Thanks for sharing such a resourceful website. The Call Girls in Dubai seem to reflect the city’s luxurious lifestyle perfectly.
Exploring the Allure of Dubai’s Luxury Companionship Scene
Ajman is growing fast, and it’s great to see services like Escort in Ajman available for those who want elite companionship.
ajman world
ajman Call Girls
I think the options listed on Call Girls in Ajman really show quality and refinement.
escort in abu dhabi
I love how detailed the descriptions are. Looks like Escorts in Abu Dhabi offer the perfect blend of luxury and discretion.
Indian Escorts in Dubai
Excellent resource for travelers looking for companionship. The Indian Escorts in Dubai presented here are truly stylish.
UAE Escorts Agency
Very impressive site! The UAE Escorts Agency looks like a trusted choice for elite services.
Escorts in Dubai
Dubai’s lifestyle is all about luxury, and Escorts in Dubai seem to match it perfectly.
Dubai Escorts
Great concept, and I like the way Dubai Escorts are presented here.
Pakistani Call Girls in Dubai
Nice site with a unique offering. Pakistani Call Girls in Dubai bring cultural beauty into the city’s elite lifestyle
Jumeirah Call Girls
Very classy presentation. The Jumeirah Call Girls look like the perfect companions for Dubai’s luxury lifestyle.
Al Barsha Call Girls
Al Barsha is one of my favorite areas, and the Al Barsha Call Girls featured here seem ideal for enjoying it fully.
Call Girls in Abu Dhabi
Abu Dhabi deserves elegance, and Call Girls in Abu Dhabi definitely deliver that experience in style.
Friday Night Funkin game has
Friday Night Funkin game has many levels from easy to difficult, allowing everyone, whether new or experienced, to experience the most epic rap battles. There are also many different mods, each with a different story and challenge for Boyfriend and Girlfriend to face. Play for free and with all the mods at fnfgo!
Reading this VESC tutorial
Reading this VESC tutorial feels like mixing paints in a coloring lab! It makes me wonder what happens when we swirl FOC and Hall sensors together, like blending crayons? The step-by-step setup reminds me of free PDF coloring pages at ColorearW.com download, print, experiment, and discover your own masterpiece!
This tutorial provides a
This tutorial provides a clear, step-by-step approach to configuring a VESC® with a BLDC motor, but it feels very technical and dense for beginners. Just like coloring pages at ColorearW.net (PDF to print for free) simplify creativity, this guide could benefit from more visuals, summaries, or flow diagrams to make learning smoother.
HEIC to JPG Converter
HEIC to JPG Converter quickly transforms Apple’s HEIC images into widely compatible JPG format, ensuring easy sharing, editing, printing, and storage.
Engineering Assignment Lifeline
Balancing university deadlines and technical subjects can be really stressful, which is why I rely on Rapid Assignment Help UK for reliable Help on Assignments. Their team of experts makes even the most complicated topics manageable. For engineering students like me, their Engineering Assignment Help UK is a lifesaver. They provide well-researched, plagiarism-free solutions for projects, case studies, and problem-solving assignments. The explanations are clear, and the work is always delivered on time, which has significantly reduced my academic stress and helped me improve my grades. Highly recommended for anyone struggling with coursework!
Ensure higher grades in academics with Assignment help online
As a student, you always try hard to score good grades in academics. However, achieving excellence in study and academic tasks is not easy for everyone. The complex topic and academic demands make the writing process more difficult for students. For any type of difficulty in the study and academic project, you can get Assignment help online in Australia from experts. Professional experts are highly trained and experienced in tackling complex projects or topics. They provide conceptual detail on the topic in a simple and effective manner. Their support allows students to acquire a better understanding of the topic and learn ways to tackle questions or subject problems efficiently. It helps you to perform well in exams and academic tasks. Getting professional assistance in a writing task, you can save time and effort to focus on other things. It helps you enhance learning and secure good grades.
Effective Ways to Contact Epson Customer Care
Epson is a leading name in printers, scanners, and imaging solutions. When you face issues like installation errors, poor print quality, or connectivity problems, how do you reach Epson support? This guide outlines the direct methods to contact Epson Customer Care — via phone, live chat, email, or social media — and offers tips to make the conversation efficient. Be prepared with your model and serial number, warranty status, and clear descriptions of the issue. Also learn when basic troubleshooting at home helps, and when it’s best to talk to a care representative to resolve your problem fast.
https://sites.google.com/view/epson-customer-service-/home
The visuals and graphics of
The visuals and graphics of this Boxing Random Game are really very high quality. You will be addicted to the Boxing Game and you will love it very much.
Basketball Stars Thank you
Basketball Stars Thank you for sharing this comprehensive VESC motor setup guide! I've been working with BLDC motors recently and this tutorial is incredibly helpful, especially the detailed current limit explanations. The emphasis on starting with conservative values and gradually increasing them is solid advice - I learned that lesson the hard way with my first build!
An online tool, Mathway helps
An online tool Mathway, helps students solve algebra, geometry, and calculus problems with instant step-by-step solutions.
