Hoverboard Motor Setup
CadillacF1
I'm trying to set up my VESC for the first time. I am using the Dual FSESC4.20 from Flipsky to drive 2 hoverboard wheels with an R/C controller. I will only be using these for forward and backward and not for steering. I am using the wizard to set up the motors. Should I be using the setting for E-Bike DD Hub Motor (~6 kg)?
I am using it with the 10S2P 36V battery that came with the hoverboard. I selected Direct Drive with a 165mm Diameter Wheel. and selected Run Detection. The detection mode seems to be working correctly. Then when I check to see if one of the VESCs has an inverted motor direction, neither of the motors turns. I do hear a hum out of them. When I try to use the Remote control, the wheels try to move and don't or they jerk violently.
I'm also getting a message that my VESC has old firmware. I tried updating it, but I keep getting the same message. I'm a mechanical engineer so I'm not used to doing any programming so forgive my ignorance and feel free to dumb things down.
Gfiuso
Hi CadillacF1,
I'm trying to make a similar build, do you know if is it possible to run smoothly at super slow speed with flipsky FSESC and generic hoverboard motor?
Best
Possibly, the hoverboard will have sensors which ought to allow torque from standstill. There's also HFI which should work similarly. You may have to tune the VESC specifically to get the slower speeds.
As this is a small group it's extremely unlikely anyone else will be able to test this out so you're largely on your own. But please do post up your attempts.
meziked
Using the Flipsky FT85BD to drive 2 hoverboard wheels (not a vesc). Whats funny is they work way better without the hall hooked up and configured like a sensorless BLDC. Probably because I do not know what I am doing and have missed something. I'm still working on fine tuning as the start is still lacking, but low speed works decent(ish).
The canbus motor detection in the Flipsky ESC software runs it perfect towards the end, then crashes the application....
I wish it would display those setting it was using, as it did a run up from a very slow speed with no chatter at all.
I'm also using aa EPRS receiver and RadioMaster Pocket transmitter with no real issues. (FPV R/C lawnmower build)
But yeah man, 20 bucks on marketplace for a used hoverboard containing for two 10amp 15 pole 36v motors and a 12HA 10s?? all day buddy!!!
