Repairing
lamak
Repairing
Is there Service manual to repair our broken boards ?
ispor4en
Subject:
Connecting VESC (FSESC75200) to Flight Controller (Matek H743) for Rover — Setup and Recommendations
Message:
> Hello,
> My name is Maksym. I am using two of your FSESC75200 AL controllers to build a tank-steering rover based on the Matek H743 flight controller (running ArduPilot firmware).
> I kindly ask for a detailed guide on the following:
> 1. Proper wiring of two VESCs to the flight controller via UART (for telemetry) and PWM/PPM (for motor control).
> 2. Pinout details for the connectors (UART2, PPM/SERVO) — which wires should be connected to which pins on the flight controller.
> 3. VESC Tool configuration for working with a flight controller (which App to Use mode, UART parameters, and whether any additional telemetry options need to be enabled).
> 4. Recommended settings on the flight controller (for example, which ArduPilot parameters are important for correct operation with VESC).
> 5. Any advice or warnings regarding connecting two VESCs to a single flight controller (for example, is it possible to combine TX lines for telemetry, or is it better to use a separate UART for each VESC).
> I would appreciate any diagrams, photos, or links to official documentation that can help avoid mistakes during connection and setup.
> Thank you for your support!
> Best regards,
> Maksym
ispor4en
Subject:
Message:
> Hello,
> Best regards,
> Maksym
