Motor won’t run when VESC BMS is connected via CAN
Samuel Pernsteiner
Hi everyone,
I’m currently using the following Trampa components in my build:
  • Trampa VESC 6 HP
  • Trampa VESC BMS
  • Trampa VESC Express
I’ve encountered a strange issue:
The motor runs fine in both FOC and BLDC modes as long as the VESC BMS is not connected via CAN to the VESC 6 HP.
When I connect only the VESC Express via CAN – everything works as expected.
However, when I connect only the VESC BMS, the motor becomes unresponsive.
And when both the VESC BMS and VESC Express are connected, the problem persists – motor does not run.
Is there something I’m missing regarding CAN setup or device IDs?
Any help or advice would be greatly appreciated!
Thanks in advance,
electricfox
electricfox's picture
Last seen: 1 hour 16 min ago
Sounds like some VESC CAN IDs are the same. Make sure to change the CAN IDs so that no CAN ID appears twice.
