CAN not working on VESC MkV
chundri
Ciao,
We have a VESC where the CAN is no longer working.
We're sending eRPM speed commands over CAN to the VESC, but it doesn't work...
However other VESCs that we command in the exact same way work just fine.
Is there some settings that might be incorrect or is there something I can check on the VESC itself (bad connection maybe or a small electrical component that I will replace)
Thanks,
Chundri
chundri
Ciao,
it turns out that it is not the CAN that is not working, the motor is actually trying to spin, but doesn't...
Does anyone have any idea what this can be related to... after succesfull FOC motor setup the motor does not work.
Thanks,
Chundri
domi.8248
hello i have a dual vesc that is not working. it was running fine until one day while running very early in the morning it slowed down like as if the batteries were low but turns out batteries were fully charged. checked the transmitter and receiver and even used a different one. both vesc turn on batteries are good but it just will not go. anyone know what i can do?
Domingo Ariza
