Dual VESC and One Motor Stops Spinning
f0n
I have a dual VESC with two motors. I am using the default parameters for a medium size motor for an electric mountainboard application. When accelerating, one of the motors spins continuously, while one of the motors stops temporarily. At the same time that the motor stops, the Duty % drops to 0% temporarily. What could be causing this behavior?
DavidjohnNeff
Last seen: 2 weeks 16 hours ago
check for faults in vesc tool and post here also how are the dual motors run input wise do you have seperate adc inputs or do you have the controllers linked on can
f0n
No faults in the log file. The VESCs are connected via CAN bus.
DavidjohnNeff
what apps do you have enabled on the canbus controller because they may interfere with it you only need adc  on the primary controller
if thats not the case try moving the adc to the other controller and see if it produces different results
