What is the recommended way to implement a new encoder in the VESC firmware?
toma
I am looking to implement a new absolute encoder via the hardware SPI interface.
For encoder details see: https://www.rls.si/eng/orbis-true-absolute-rotary-encoder
What is the recommended way to implement that:
  1. Add to the  "encoder.c" and "encoder.h" code
  2. Add the code in a separate file included/referenced in the "encoder.c" and "encoder.h" files
  3. Create a custom application
Thanks,
Toma
miniwb
Did you ever figure this out? Looking into the AM4096 chip series (specifically the RMB20) and I'll have to figure this out too, albeit a different implementation.
6ytep37
Hello. Please tell me how to select or register AS5134 in the sensor selection menu. Thanks.
hi world
James Donker
Did you ever figure out a way to do this? I'm trying to use a Magalpha MA302 sensor through SPI myself
