HIGH Voltage (350v-450v) VESC
9 posts / 0 new
athlon
Hello ,
I'm thinking to make an high voltage version of Vesc ( 350-450 volts )
there is someone already doing it ?
nickk
hi,
What are the current requirements you have in mind?
athlon
Low current from 40 to 60 A , I would like to keep as much as possible the original hardware topology and move to high voltage by using SiC or Gan mosfet  (Gan preferred)
nickk
I'm also looking into possible designs for a Vesc with these specifications, but i am not sure that only changing the mosfets will be enough to achieve a higher voltage rating.  I think that the DRV8302 gate driver also needs an upgrade to accommodate for the high side switching voltage. Do you have an opinion on this matter?
athlon
Yes for sure , the driver and the current sensing need to be updated with galvanic insulation
soaring
Howdy!
Any progress on this?
I'd also be interested in a high frequency (20kHz - 4Mhz & high-voltage (10 - 50kV) VESC...  In exchange the Amps would be moderate with 1-3A input...
I'd only do it myself, if there is nobody else with way more know-how and experience than myself that would enjoy doing it. I'd happily buy the parts and pay for R&D for such an individual...
Cheers :-)
El3ctr0n1c
I made some time a go fully isolated VESC hardware. It was early alpha stage but it works :).
Now i works on free time (not too much free time ;/ ) on VESC-Brain. It controls external power stage (MOSFET + drivers + voltage/current sensing).
Using GaN isn't good idea. They are very expensive and STM32 can't run them so fast that they can. SiC are best choice (but not cheapest). They reduce power losses significant to IGBT.
Regards,
Marcin
thewho
Artabotak
Artabotak's picture
Do u still do it?? Do u have the schematic and frimeware?? Iam interested.
Artabotak
