How to connect 5 Pin Hall Sensor to 6 Pin Hall Sensor Connector
tinytuna38
I have bought a 6374 BLDC Motor with a 5 Pin hall sensor but my vesc has a 6 Pin connector. In the datasheet of the vesc (makerbase vesc) i found out, the black and red cable are for +5v and ground. And then Cables (yellow, blue, green) for H1, H2, H3. The last white cable ist used AS an temperature sensor cable. The datasheet of my motor is not very detailed, because it is a non brand motor. It has a black, red, orange, white and yellow wire connected to its 5 Pin JST. So now my question... does anyone know which color from the motor hast to be connected to which color from my vesc. have already tried various different connections but when testing for hall sensor in the vesc software, I always get the error "Bad FOC Detection Results Recived". This is also my first time setting anything up with the vesc software, so maybe it could just be a simple mistake from me. Would be thankful for any Suggestions to fix this problem.
DaganWal
Last seen: 6 months 4 weeks ago
The pin out on the VESC to motor, sorry for the poor hand writing.
Nineballshot
Check your hall sensors and make sure they're all good There are several ways to check those sensors. Search YouTube. You'll find it.
