PPM Signal not recognized
9 posts / 0 new
nopf
Hello Community,
I am really confused with my controller ( 4.10 dual ).
Setting up the motors is ok, setting the input to PPM - no response.
i
...... several attempts without any effect.
Connections as the wiring plan and I also see the signal from the sender on the wire between receiver and Controller.
The VESC-Tool does not show any when moving the sticks but the Osci shows correct.
PPMApp is active.
Help is seriously wanted....
Norbert
Fbi
hi did you mnage to solve your ppm problem i have the same
Fbi
ok figred a way
1.update firmware over can on primary bus 1 make sure both sides Vesc  lights are flashing
and it updates both when done wait 12seconds switch off wait 12 seconds switch on reconnect
2.follow motor setup when done adjust motor and battery amps accrding wrti ti motors only
disconnect unplugged usb and plug into B or secondary port this is side where the ppm channel is connected to
3.now on seconday run input wizard select firsts channel or vesc or (b seconday wich now b now sees as primary main channel .select  ppm or first picture
3 ull see remote with be active(considering remote and receiver is paired if not sometime ok ) not set max an minapply do this 3 times then next set ramps done all good to go
if you need to do remote settings only do this on this plugged in channel and only write to program do not write to motors o any other adjustment on this channel not across can not vias versa
meaning on A port only write motors and b port only remote programming
if do ..and kicks out you have to run the whole sequence again
hope it works for you
enjoy
hope you come right
nopf
my controller is:
and it updates both when done wait 12seconds switch off wait 12 seconds switch on reconnect    - Done
2.follow motor setup when done adjust motor and battery amps accrding wrti ti motors only   - Done
disconnect unplugged usb and plug into B or secondary port this is side where the ppm channel is connected to ???
There is only a centered connector for both channels. Connection internal by can-bus.
3.now on seconday run input wizard select firsts channel or vesc or (b seconday wich now b now sees as primary main channel .select  ppm or first picture  - I can only select the connected channel...
meaning on A port only write motors and b port only remote programming  - this sounds strange.........
But - still no success
nopf
Update:
PPM Sinal is ok!
Norbert
nopf
I did some more attemptions....
The wizzard always recognizes the wrong timing.
between ~ 0 and ten ms is wrong due the specs of PPM signalling and the real values outpt from the receiver.
My fear is to have a defect controller and kicking several hundred € into garbage.......
Norbert
nopf
If it depends on a newer firmware, which one I schould use ( without risk of damage ) ???
nopf
Update:
I got the hint to use VESC Tool 3.00
Installing 3.00  Done
Next is flashing firmware . - Done
Configuring motors  - Done ( no receiver connected due possible distortion in signals )
starting the wizzard for remote
Choosing ppm
Screen show the  default timing ( ok )
Plug in the receiver, switch on sender - checking signal on oscilloscpe ( ok )
Timing detection show some values between 0 an 10ms measured, which are wrong values. reset to default and re-detect the same........
I assume the ppm part is not usable. - garbage
nopf
Update:
I tried to contact Flipsky.
There was a short try to help. When telling the supporter that all advices show no success - deep silence.
One more question to Flipsky for help: still no answer.
Thats not what making me happier. Also no discussion about warranty or anything else.
