Handbrake in PPM mode
bdesvaux
Last seen: 6 hours 13 min ago
I use the handbrake function in order to maintain a zero speed on my motor while facing high torques. It works very well in UART control mode.
I'd like to make it work in the PPM control mode but I can't find out how to do that. I tried to set different values for timeout and brake current but it doesn't seem to use the handbrake function. Has anybody had the same issue ?
Is there anything I could do using the smart reverse function (I don't really understand how that works) ?
Thanks a lot,
Benjamin
flez1966
Last seen: 1 week 2 hours ago
handbrake function?
is this like 'wheel lock'? my old generic silver box controller had a wire to the alarm for this and I really miss that feature
flez1966
bdesvaux
It's a settable current that maintains the motor at zero speed. You can try it in the bottom of the tool when in UART control, "HB current".
We actually found a way to use it in PPM mode by writing a short script, defining when it should be used or not depending on the PWM signal.
its4ankit
Last seen: 4 weeks 1 day ago
Greetings,
Can you help me with the code which you used to solve the handbrake on ppm issue. I want to test something similar and use braking on ppm mode when duty from the joystick is near about 0%.
Thanks in advance :)
its4ankit
Greetings,
