Disable Regen braking below set erpm
HighV3locity
Is there a way to disable regen breaking when below a certain RPM or erpm while using ADC brake center throttle control. Don't want the brake active when stopped or under 5mph. Makes backing up or moving the bike around a hassle.
flez1966
I do hope someone answers you on this as I have the same issue with mine, and not only does it  make moving it a pain but I am using a keyswitch to the SW line and if its  in regen it ignores the key switching off until the throttle is at a neutral position, so i have to remove the key and 'blip' the throttle to fully power down, if i forget its not a huge power drain but the ''holding current' through the hub causes interference into the bikes alarm, so i walk away and 1-5minutes later the alarm goes off annoying everyone...
flez1966
