being able to connect VESC 6 MK VI with servo
mmobayed
I am working with a VESC 6 MK VI and connected it with the battery, motor and servo. By following the https://f1tenth.readthedocs.io/en/foxy_test/ guide, the VESC works in the end. Yet I am not too experienced with the VESC and the VESC tool 6.02. I can run tests so that the motor rotates the wheels, but not the steering angle through the VESC tool 6.02, I tried to adjust the position parameter from zero to 15°, but once I pressed play, the motor started making weird noises.
I adjusted the motor type (in  motor settings/general)= BLDC and adjusted the values for the PID controllers (in  motor settings/PID controllers).  As well I also adjusted the APP to use = PPM & Enable Servo Output = true  (in  APP settings/general). Control type = PID position control: 180 (in. App settings/PPM). With these settings, I was hoping to get the servo to run through the VESC tool. So far I have not been able to get the servo running through the VESC tool 6.02.
Firmware I used VESC_default.bin and a custom file, which I found on the F110 Git Hub.
I would appreciate any help if anyone knows how to control/test the servo through the VESC with the VESC tool, please let me know.
thank already in advance!
Srihari293
We are facing the same issue. Any help would be greatly appreciated.
Srihari
