Torque control setting
mambazhasa@uni....
I am using VESC 6MKV speed controller, is it possible to modify the settings to run the motor in torque control, if so please tell me how to do it.
Best regards
Arun
Current control is basically torque control. The relation in between current and torque is almost perfectly linear.
Davidepolpi91
it would be possible to implement torque control from external sources through CAN communication? The CAN function SetCurrent operates setting the limit in operating current? Would it be possilble to set a runtime current setpoint?
Davidepolpi91
Hi Frank,
it would be possible to runtime set the setpoint of the current control loop through CAN?
