which configuration file I should change to make operate a VESC at 800 Volts
JCordova
Hi everyone. I am building a 3 phase High Voltage ESC based in the HW4.1. I already build the hardware and tested it with another code I wrote for a 3 pahse Dual Active Bridge. All the stages of the power converted work as intended: power, gate driver and controller.
Now I want to use the VESC tool to control a High voltage motor: 800 volts.
I went through all the configuration files that are need to run the version HW 4.1 and I manage to spin the motor with 110 volts. But when I increase the voltage above 120 volts controller just shut-down. Any idea in which other configuration file should I change the arameters to make it works?
Thank you
NOAI
Last seen: 5 months 1 day ago
In hw_410.h file have voltage devider VIN_R1 and VIN_R2 its ANALOG input in MCU controls OVERVOLTAGE and UnderVoltage Setings Limit in same file on the batom of it.
