Vesc6MK3 stops responding to throttle input
idlebear
Hi there -- I have a Vesc6 MK3 updated to the firmware included with the 6.02 vesc tool release.  The vesc is mounted in a 1/10th scale RC car (based on the f1tenth.com build) in sensorless mode and connected via USB to a TX2 running linux. When I boot the system, everything runs fine and I can drive the car without issue.  However, after a short while the Vesc becomes unresponsive to speed requests. It is still responding to servo requests, so the vesc interface hasn't crashed.
When it gets in this state, if I connect the vesc-tool, I can read the current state and command it to run (with real-time monitoring).  When I do this, the side gauges in the tool show a velocity but no current draw.  I've attached a video (https://www.dropbox.com/scl/fi/tl6b5a5z3uhiafpz293i2/vesc-unresponsive.m...) so you can see what I'm talking about.  There is no sound as if it is even attempting to drive the motor.
There is no temperature sensor or other connections between the vesc and the motor other than power.
If I reset the power, operation immediately returns to normal (until the state recurs)
Any thoughts or comments would be appreciated!
idlebear
Some more info -- I tried this again with a larger battery just in case it was a power problem, but no change.  However, I can trigger this 'servo only' state by rapidly flipping the servo output (full left, full right, repeat...).  After a couple flips, the throttle no longer responds.
