Type of Hall sensor
Faheem
Type of Hall sensor
Hello guys,
I am trying to build a custom brushless sensored motor with hall sensors but unsure of which type of hall sensors to be used for the VESC.
Does the hall sensor outputs needs to be : 1) Voltage type, 2) Analog type, or 3) Digital Type.
Thank you and appreciate if anyone can answer.
pc.buher
Last seen: 2 weeks 4 days ago
hi
i build a bldc motor too and i used this sensort and it works well
https://www.doitsmart.hu/wp-content/uploads/2020/11/A3141-4.pdf
Liker motors
Last seen: 6 months 4 weeks ago
Bipolar Hall-Effect Digital Position Sensor is what you need. Honeywell SS41F or similar are good choices.
Faheem
Thank you so much for the input!
