Hub motor e-bike not recognized
olivierskypullc...
Hello everyone,
I have an e-bike whose controller is broken so I am thinking to replace it with a VESC 6 I have. The problem is I cannot get it pass detection. In BLDC auto detection it stutters, then beep and I get a detection failed error. The motor is an ABB 3-permanent magnet AC synchronous motor, wired in star configuration. I connected the neutral to the - of the battery. Its nominal power is 250W.
What can I do to make it pass detection ? I tried increasing duty cycle and current, it didn't worked.
Thanks in advance !
Olivier
Last seen: 2 days 10 hours ago
The neutral of the motor should not be connected anywhere. Connecting it will definitely cause problems.
olivierskypullc...
Thank you so much, I've tested it and it worked ! I was a bit confused by the ground and neutral definition, but it works ! Thanks again !
Ampit
Ampit's picture
<p>hey there. I just thought I would ask since you have been down this road. I have a geared 1500w rated e-bike hub motor and I rarely get it past decetion ( usually says IO have a short or ABD current over limit check to make sure its sensible. ) this is a 1KG motor the heaviest or most powerful geared e-bike hub motor anyway. 30 poles, 20' wheels&nbsp;I am not sure what to do here. it usually shudders back and forth. i been down this road before with grin tech's phasrunner so I kinda have a clue. not very familiar with duty cycle at all. on the FOC setup where you pick your motor... mine is heavier than 6kg like the picture has, should I pick the heavier outrunner. my resistance and inductance seems way heigher thatn I remember seeinbg when I would run autotune ( decetion ) whith the phaserunner.
lucas reti
