Flipsky 75200 ALU not booting up
Metastasis
No matter what firmware is being uploaded (with ST Link), the controller won't boot (no green light). Firmware used were 'VESC_default.bin's. How can I fix the bootloader?
Metastasis
STM32CubeProgrammer says the core is locked up. What's the cause of this?
B1996
Last seen: 1 year 3 days ago
if you flashed V6+ firmware and forgot to turn off phase filters or didn't uncheck restore default configuration on motor detection or something, you most guaranteedly have damaged the STM32
AFAIK they come stock with 75_300_R2 (official VESC) firmware, which it certainly SHOULD NOT use and is Wrong
so if you updated to V5.3 or up or something you may have damaged the actual STM32 because they come with incorrect firmware.
edit: Man i'm late, didn't notice the date.
