Hall Sensors Not Detected
leymane
I have the FLIPSKY 75100 ESC and the  Flipsky 6374 Motor with sensors. VESC tool is not able to detect the hall sensors with the automated detection.
On the esc side, the voltage from positive (red) to ground (black) is 5.3V. H1,H2 and H3 is about 3.3 volts. I did have to move a pin on the sensor connector because the esc is 6 pin and the motor is 5.
Are there any suggestions how to get this to work or at least figure out if one of the components (motor or esc) should be replaced? Do I need a different VESC? Otherwise, the VESC tool works great with this setup.
I would just like more control over the motor at low speeds, especially startup, so that's why I am trying to get the hall sensors to work with the esc.
For reference - (https://flipsky.net/products/flipsky-75100-foc-75v-100a-single-esc-base-... and https://flipsky.net/products/flipsky-electric-skateboard-motor-r-6374-19...)
Thanks for any help you can provide.
leymane
kiwipaul
did you resolve this ? - i have the same issue.
ministeve2003
I Had this issue... had to go to FOC tab,,, on general tab select hall sensors... then go to hall tab... and run scan button at bottom... it will spin motor and replace all the 255 numbers with correct ones...
Steven Kight
Ben26
Last seen: 2 years 1 week ago
Just had same problem with all sensors showing same voltage, turns out the wires on the pcb in the motor where the sensors are mounted is broken on mine so check all the wires are actually connected! 20241021_204518.jpg
