Sudden drop in speed after releasing throttle in FW mode
shokrabi
Last seen: 1 week 23 hours ago
Hi guys, I am using the vesc 75/300 with my sur ron build. When setting field weakening above 80amps the top speed is significantly increased compared to below 80a but the speed is not stable and fluctuates + - 3mph as well as sudden full braking when rolling off the throttle at top speed. This issue does not happen below 80a of field weakening but the top speed increase is not substantial.
Is there any related settings to smooth out the field weakening power that I can experiment with?
80a is a lot! Try to lower the value.
shokrabi
With 60a I can receive a 5mph increase in top speed. with 80amp it becomes a total 13mph increase which an ideal increase that i don't wish to go higher but the above issues begin to happen.
Phill Dixon
Phill Dixon's picture
Sounds similar to my brake hiccup post
DeuceDos
Did you ever figure it out? Interested in this but don't want magic smoke lol
DD
