help - vesc tool configure for edf turbine D3541 1450KV 6s DoBoFo
Everton C
hello everyone,
I try to configure my edf turbine in vesc tool bldc mode but it's only return error. I'm using a Dual FSESC6.6 Based upon VESC6 200A with a LiPo 6S 70C.
I need to configure the eprm for 208800 ERPM too. I know that the vesc6 only suport 160000erpm, but if someone managed to set up an edf i appreciate the help.
turbine: D3541 1450KV 6s
That won't work. You will be lucky if you gat 95K ERPM. Also you should go for FOC. BLDC is outdated. These EDF motors typically feature a very low inductance and that might als be a thing you face trouble with. It is better to go for individual gate driver deigns like the VESC 6/75. Is better for low inductance motors and can reach higher ERPMs.
The VESC 6/75 is very similar to the 75/300 shown in the video below.
https://www.youtube.com/watch?v=fbK2dcoYS7g&t=199s
