forward, reverse, regen
ronmotor
I have a two motor setup on a four wheel cargo bike. two wheel driven. I have two controllers  100-250 from Trampaboards.
set up:  two thumb controls. one for fwd speed, the other is regen.I have been unsuccessful to have reverse to work and also leave these two thumb controls at same time.
If I remove the reg from the set up I can get a smooth fwd and also reverse.
Has anyone done this successfully. ?
ronmotor
can I get reverse just by reversing the phases on the motors without doing any program setup?
rondoc
velolac
Last seen: 5 months 16 min ago
I do no not have experience with regen yet. Have you tried "Current reverse ADC2 Brake button"? Dunno what the button means here, or how exactly the others behave. Maybe you need to code a new type of control. Hopefully lisp will be easy to use for non experts too.
