Total ODOMETER counter via real time logging feature request
janzobanzo7
I have VESC on my homemade electric scooter, I love it so far!
The only inconvenience on vesc for me is, that VESC does not record total ODOMETER (total travelled distance [km], on that vehicle).
I heared, that hardware of VESC does not support that kind of RAM (that remembers through cycles).
But this feature could be implemented only in app with REAL TIME LOGGING enabled, so when you connect to the VESC, it reads certain .csv file and updates the total ODOMETER..
I have one smartphone constantly mounted on my scooters handlebar, that constantly shows RT data.
I would really apprechiate this integration, for what I need, VESC is perfect solution, I really love it!
Sincerely,
Jonathan
Seems like Odomter is implemented as of version 5.3 but saves only if shutdown function is used (to save write cycles).
Interestingly, you can also change the odometer value manually:
https://github.com/vedderb/vesc_tool/blob/6b11c86a0caef89d807b40d8503976...
janzobanzo7
thank you for your reply..
But this is somewhat inconvenient to use..
Is there a way to automatically write current ODO meter when the BT disconnects (when I turn OFF power to VESC) to .csv file,
and automatically read previously written ODO from .csv upon power on and sucessfull connect?
Sincerely,
Jonathan
misosvrki
anything new about the odometer?
misosvrki
Dominator2
hi, how can use shutdown?
Lennart Duijn
Last seen: 25 min 50 sec ago
VESC BronzeVESC Free
This would be great indeed.
Kind regards,
Lennart
