Motors spin up during detection but then won't move
13 posts / 0 new
jordan314
Last seen: 6 years 12 months ago
I have two Maytech ESCs (came with hardware 4.10 firmware 3.3 upgraded to 3.40) two Maytech Hubmotors with hall sensors, and a 10S Lion battery.
The specs are:
Motors:
Size 90mm
Voltage 24-36V
Max Amps 22A
Max. Output Watt 800W
Resistance 0.557‐0.577
The motors are connected to the ESCs with a hall sensor adapter (and the three phase wires).
Battery:
Koowheel 5500 mAh battery
Max Amps: 30A
I tried running the motor setup wizard with these settings:
Max Current: 20A
Max Current Brake: -20A
Battery Current Max: 25A
Battery Current Max Regen: -10A
Voltage Limits: 34V / 31V (10S Lion)
First I tried FOC detection on one of the maytechs, and the motor would spin up, but then when I tried to use the arrow keys in arrow key mode after the setup the motors would cog but not move. The ESC would blink red 3 times when I hit the arrow key.
I tried BLDC mode next on the first maytech and it would spin up in detection but then also not move with the arrow keys. I then tried BLDC on the second maytech and it would move with the arrow keys. I've run the detection multiple times on both ESCs, and sometimes the cogging happens on both and sometimes just the first one. No red blinking lights other than the first time I tried FOC.
Here are the settings that the motor setup detected in BLDC mode:
I 5.00 A
150.0 ERPM
D: 0.05
Detection Results:
Integrator limit: 111.01
BEMF Coupling: 433.58
Detected hall sensor table: 255, 3, 1, 2, 5, 4, 6, 255
I'm wondering if I'm not sending enough current with the arrow keys, or if I burned out the first ESC with FOC mode?
In the bottom left corner my settings are:
D 0.20, 5000 RPM, IB 3.00 A,
I 3.00 A, P 0.00, HB 3.00 A.
What should I try changing?
Thanks,
Jordan
TastySoul
I have the same problem. I have 90mm HUBs. Durning detection they sound and spin like normal. But after detection, when i try to controll by left and right arrow they twitch an make sound but dont spin.
And when controlling with UART they spin in opposite direction but first they twitch and whine loudly and the spin is not nice and smooth at all. Also i cant get them to spin with buttons prev and rev durning FOC configuration.
motor detection values look ok. Also current set is 26A which is according to motor specification. VESCs are connected through can.
TastySoul
motorclick
I'm also running into this problem. Have you guys figured it out?
Kozel
I have the same problem.  I found a fix, or at least a workaround.  App Settings/General/App to Use/    When this field is set to PPM & UART I am getting this problem sometimes but not always.  So far, changing it to UART makes the keyboard work again.  If your actual throttle is PPM, you will need to change it to PPM when you are finished working on the computer.  The setting PPM & UART was working earlier today, with both the remote & pc (& bluetooth module) all working at the same time.  With the same FW & HW, it does not work now.  So IDK what is going on exactly, but the workaround is working reliably so far.
braydengast
I'm having a similar issue on my 4.2 flipsky esc it runs the detections and spins up with the arrow keys but in any way, I cannot get the controller to work any suggestions?
brayden gast
Pakran
I'm also facing same problem. The VESC tool detects parameters completely and motor spins normally, but after detection, I tried running the motor by all the following ways but I constantly receive ABS_OVER_CURRENT fault and motor doesn't start spinning.
1- Arrow keys
2- ADC App (using throttle)
3- Experiments Tab in VESC tool
Does anybody knows what should I do to make motor runs? It doesn't matter for me which APP you recommend, I just want to make sure everything is ok and there is no problem with hardware or source code.
brian adilman
I have the same problem. I would be happy if someone found a solution
סמל 'אומת על ידי הקהילה'
dlbogdan
same problem here. Maytech 4.12 updated to 5.3. Behaved the same on the original firmware 3. something.
argon338
check voltage detected buy VESC.
in my case it see wrong voltage 27 instead 42
so cutoff at motors cfg  set to 34v and blocks rotating off wheels
I set it to 22 and motors just start to spin.
zapshe
I was having this same issue. I realized that the order you connect the 3 connectors to the motor matter. Most ways caused the motor to stutter. One way allowed the motor to spin, but it was a very odd and unstable spin. Then finally one of the 9 total combinations allowed the motor to spin smoothly.
2821223
I have the same problem. I would be happy if someone found a solution!!
NoMartyNoParty
Same here the motor works fine during detection but then as soon as I use the "detected" values it does not spin as smoothly as during detection. Also when I use the RT app the current is always just spiking and not constant like during the detection. Why is it working differently, I'm so confused.
Chris
KDoc
I had the same problem. VESCTool detection for motor and Setup for throttle ran perfectly, but as soon as I tried to use the throttle/motor after setup it only ran at maximum. The problem I was having resulted from writing the parameters to the VESC on the setup page and then pressing next. On the next page I also pressed next and this finished set up. I finally noticed that VESCTool was not maintaining the “write to Vesc” when I went to the last page. On the last page of Setup I noticed in the top box the Vesc was setup for current cycle not duty cycle (I had programmed duty cycle on the previous setup page). So, after running setup and writing to Vesc on the second to last page I pressed enter and in the top box of the next (last) Setup page I changed current cycle to duty cycle, wrote this to the Vesc and everything worked perfectly.
I have no idea why “write to Vesc” on the input page was not carrying over to the last page, but once I did this I couldn’t wipe the smile off my face.
Everything is good now, but if someone knows what I might have been doing wrong (besides not “ALWAYS WRITING CHANGES TO VESC “on every page) please let me know.
I think VESCTool is incredible and if the above can help I am only too happy to contribute my little bit.
If my explanation seems a little confusing ask for clarification and I will try to help.
