How to Enable kill switch support in Firmware 5.03
iserai2r
May I know how to enable kill switch support feature in Firmware 5.03?  With this feature, could I install an emergency stop button?
Thanks.
David
j.konrad
Yes.  Look under App Settings, General, General, Kill Switch Mode.
Verbatim from Help:
Kill switch input. When this input is active the motor is disabled and optionally braking if timeout_brake_current is greater than 0. The kill switch overrides all other inputs and can be used as an emergency stop.
The following modes can be used:
Disabled
No kill switch is used.
PPM Low
The kill switch is active when the PPM input goes low.
PPM High
The kill switch is active when the PPM input goes high.
ADC2 Low
The kill switch is active when the ADC2 input goes low.
ADC2 High
The kill switch is active when the ADC2 input goes high.
iserai2r
Thanks for Sharing It works.
iserai2r
Thanks. It works.
moose09876
Last seen: 2 weeks 2 days ago
This is not working for me. ADC2 High works, but ADC2 Low always disables the drive. Any ideas?
rodrigo.baronio
if I want to use the kill switch, like PPM high on the vesc4.2 would it be on the 3-way cable, 5v, GND and signal, in the case of no signal would I send 5v?
