please delete!
return97
Last seen: 2 weeks 19 hours ago
please delete!
please delete!
thank you!
notahorse
Hello Return97,
Couple questions
What hardware are you using? (Make & Model & Firmware Version)
Can you export your motor config and then copy & paste the results here?
Are you using Regen at all?
return97
no
i don't use regen
Most likely your high battery voltage kills mosfets. 100v is too much for 99% of vesc running hardware available on the market.
return97
I can work continuously at 300A!
But I feel inefficient! Motor Kv value: 75
At 200A current. Erpm is only 57000
My BLDC test has never been successful.
