VESC 6 FOC wizard and current limitations.
Bor Zabric
Hello.
I set up a C80100 6KW motor on a VESC 6 with the FOC wizard.
It automatically set the phase current to 110 A That seems a bit high to me. I know the hardware limit is 120 A.
How safe is it to run it that hard ?
Does anyone have any experience pushing it to the limit ?
Im using it to run an ebike at 12s. A failure would not be good.
Greetings,
Bor Zabric
It will be fine at that current, if it starts to get too hot it will automatically reduce the current. You can turn it down a bit if you want to at a reduction in torque.
