When I mount the propeller on the motor ,I get a new promblem
moto_guy
moto_guy's picture
Hi everyone,
 When I mounted the propeller on the motor ,I got a new issue on my VESC6  ​ .
1: BLDC mode.
When PPM throttle  is up to 55% above , I will hear some "clicking noise" from motor,at that time the battery amp is about 11 A@25v in BLDC mode.
DutyCycle is higher ,the noise is  higher, when DutyCycle up to 65% , it failed  and stoped in BLDC mode.
If DutyCycle is under 50% ,everything is fine .
2: FOC mode
 When PPM throttle is up to 55% above , I  heard the noise from motor too .
DutyCycle is higher ,the noise is  higher.
DutyCycle can be up to 95% ,it's better than BLDC mode  but the noise is still a  problem.
Throttle under 50% ,everything is fine in FOC mode .
if no payload on the motor ,it run OK  both BLDC and FOC mode.
For me every step forward will encounter more problems :-)...
Thanks.
moto_guy
