Negative Current Issue
uwdxa
Im using the FSESC 6.6 Board from Flipsky with the motor lehner 3080 -> http://www.lehner-shop.com/en/inrunner/series-30/3080.html
The motor is running in FOC mode sensorless but with an negative current. thus, the speed controller can't work and the rpm raises to max.
How I can avoid this? Does anyone have a solution for this strange behavior?
Thanks a lot!
Alex
IanG
Last seen: 6 years 4 weeks ago
Hello!
I had the same issue, but I think I have solved it. Please try to go to the FOC menu and find the Advanced, and then switch the Sample in V0 and V7 from false(default) to the true.
Z.G
IanG
