Firmware Modification Basics? Changing app_adc.c
striderkent
I'm new to the VESC and having fun messing with it, but it seems many of the things I want it to do with ADC inputs I'm having to create external analog circuitry.
I'm sure that changing the firmware / code could create the same effects for me, but I'm completely lost as to how to make these updates.
Specifically: I want to have it look at ADC inputs and do certain if / then / else with it. I'll figure out the coding later.
Where I'm stuck: I'm looking at the app_adc.c file. Modifying that and saving it is self explanatory...I assume.
What are all the steps to:
Taking that modified file and putting it into the firmware to upload to the VESC?
Everything I find on the process is very high level.
striderkent
Also, how do I pull firmware OFF the VESC that I'm using? I want to make sure I'm only modifying what's already on there, not assuming that the files on github are current to my VESC.
