PID - Position Angle Division
robo_studienarbeit
Hey guys,
I have a few questions to the PID Position Controller. I have setted up my BLDC Motor with an ABI Encoder, everything is fine. I can reach the positions from 0 to 360° correctly, if the Position Division Angle is 1 ! With the realtime data I can see that the PID_pos_now value is also zero when I set the position control to 0°.
The problem is that there is a gearbox between the mechanical end position. INFO says, with Angle Division I can map one control rotation to several motor rotations. Now I am trying to set up a Factor of 2. When I set now an angle of 0°, PID_pos_now is showing me 320°. Can somebody explain me why this happens? I have already looked up the code around mcpwm_foc.c but I can not find why 0° does not correspond 0° when angle division factor is not equal to 1.
I have also tried to set up the encoder again but it does not work. When I switch back to factor = 1, PID_pos_now corresponds again to encoder angle in realtime data.
Nellieorton
Position angle division is showing this time. Hope you check all the things which is showing you on the trustmypaper.com review page. I would like to tell you all the things which show you the devisions and also show you the positions on the page.
