vesc <-> arduino micro troubleshooting UART issues
fourchette
I'm trying to get the simple UART example from SolidGeek arduino UART lib to work (on an arduino micro)
https://github.com/SolidGeek/VescUart/blob/master/examples/getVescValues...
The sample (and lib) does compile and upload just fine.
However, all I get is "Failed to get data!" message that seems to happens when there is a hardware communication problem.
VESC firmware 3.4 (i used the latest VESCT_tool to configure them).
  • I tried making several UART cables. I check the 5v betwen 5V and GND. I used a multimeter to check connectivity between all 4 pins.
  • I tried using 2 different VESC (all hardware 412 and fw 3.4, one is a focbox from enertionboards, the other is a chinese ESC from aliexpress that we realised when we receive it that it was in fact a VESC board).
  • I tried reverting TX/RX
Nothing worked.
How can I troubleshoot the issue?
fourchette
apparently it was a baudrate issue: the one in the github link above and the defaut baudrate in the vesc did not match. i changed the arduino code to match the vesc config and it worked.
