FAULT_CODE_DRV Motor not spinning
Mightyorc
Last seen: 8 years 4 weeks ago
So i just finished my board and has been working for a couple days.
Today i tried it and motor does not run. Connect to VESC tool and get fault when running and monitoring Real time data
Fault : FAULT_CODE_DRV
Current : 0.6
Current filtered : 0.1
Voltage : 41.20
Duty : 0.005
RPM : 2.0
Tacho : 49
Cycles running : 1
TIM duty : 263
TIM val samp : 131
TIM current samp : 26505
TIM top : 52747
Comm step : 1
Temperature : 33.40
i get red blinking light on my VESC when i use my remote, blinks 3 times and then back to normal. The fault only happens when using the remote but then goes away.
This is a brand new VESC...
Any ideas?
