VESC BMS CAN update rate stays at 7 Hz after changing the setting in VESC Tool
sYn
Last seen: 4 days 15 hours ago
Hi everyone,
We’re using a VESC BMS in a prototype with a 28S11P battery pack. Our torque control uses the DC pack current measured by the BMS to calculate the maximum torque we can allow at any given moment. We’d like to get fresh current readings over CAN as quickly as possible.
We’ve tried changing the CAN update rate in VESC Tool, but the message carrying the pack current still arrives at around 7 Hz (roughly one frame every 140 ms), regardless of the setting.
Does the update rate setting in VESC Tool apply to this particular message? Is there a way to broadcast the pack current more frequently, and how often does the BMS itself produce a fresh current reading?
Thanks for your help!
Daniel
