External Wheel speed sensor
Nöner
Last seen: 3 weeks 3 days ago
So. About 3 days ago my flipsky Vesc 75100 pro v2 got delivered  everything went well, I connected it to my Bafang g340 midrive motor.
It also works well with the internal 4-pin PAs sensor connected to the RX and TX. But the problem is that in Germany there's a 25km/h speed limit or limit for e-bikes. And since I have an 8-speed , so I can forget about the ERPM limit, which would restrict me in every gear, and the motor would start vibrating as soon I reach the RPM limit.
That's why I wanted to connect a 3-pin Hall, or rather these classic sensors with magnets, to the rim.
Then I asked Ki what i needed to do it told me to wire the singal cable from the sensor to the PPM pin on the vesc and had him write me a Lisp script. Well, that didn't work and almost bricked my Vesc.
I have good Knowledge about mechanics and electricity, but I'm a complete noob and a beginner when it comes to coding
I'm very happy with the controller; I'm amazed at how it performs, even with my old 36-volt battery, and I want to try and get it working with the sensor. I hope someone can help me, and I would be very grateful
thrasher7811
Last seen: 2 weeks 3 days ago
From what I could find in the documentation, the PPM pin is for reading a pulse-based signal.  A hall sensor will go high when the magnet passes by, correct?
This is probably an overcomplicated solution, but you could build a small MCU to handle the hall sensor reading and conversion to speed.  Then, send the speed data to the main controller over CAN bus.
From what I can tell, LispBM can read from the CAN bus system.
Hopefully someone else will have an easier solution and we can both learn something.
Just getting started.
